Hesitation after Dyno tune with greddy?
Old 04-22-2004, 06:05 PM
  #41
S2KSuzuka's Avatar
Why not post your thoughts and inform everyone
Mitch
Old 04-22-2004, 06:12 PM
  #42
BlueS2000Boy's Avatar
well i have the same or what i think is the same problem with my car as he does. i don't have the emanage i have the vafc. but i get the same like hesitation at certain throttle points. i belive its because my Vtec was dropped to 5300 in and 5200 out. but my car has not been dyno tuned yet. just lowered vtec. i think because of this is the reason i have the hesitation. since all i did was lower my vtec all my readings on and air fuel settings are the same. the same would apply for jow, if his car was either under tuned for his vtec settings it would give the same feeling mine would.
Old 04-22-2004, 07:01 PM
  #43
MacGyver's Avatar
Fyre, Someone will have to correct me if I'm wrong on the oil line setup, but...I believe the VTEC solenoid engagement is like a closed-end pipe. A valve will open to let in the oil pressure and engage the VTEC pin/cams, but since the "pipe" is not a loop, no pressure is lost to the VTEC system (like a 10' and a 20' garden hose...one is longer, but they still hold the same pressure). If that's truly the case, then accelerated wear is not an issue.
Bullet, Next time you need a screen shot, press the 'Print screen' key. Open up Microsoft Paint and press <ctrl>-V (or 'paste' in the edit menu). Voila, instant screen shot, no need for digital cameras taking crappy shots off of laptop LCDs.
Old 04-22-2004, 08:23 PM
  #44
Slows2k's Avatar
[QUOTE]Originally posted by Wesmaster
Old 04-22-2004, 08:51 PM
  #45
Fyrestrike's Avatar
Old 04-22-2004, 08:52 PM
  #46
Fyrestrike's Avatar
[QUOTE]Originally posted by MacGyver
Fyre,
Old 04-23-2004, 04:34 AM
  #47
beroznikmal's Avatar
[QUOTE]Originally posted by bullet1123
anyway I tried to take some pics of the map trace...i hope you guys can read them!!!!
http://gallery.s2ki.com/imagecatalog/image...eview/138278/6/
Old 04-23-2004, 05:03 AM
  #48
turbo_pwr's Avatar
Hmm that's a good point did he start with a new map or use the one that Jenner had in there? I never used the emanage so it wouldn't have my settings.
Old 04-23-2004, 05:24 AM
  #49
Wesmaster's Avatar
Originally posted by Slows2k
Does any one Know if the the last RPM range of the 16 is set at 8500, will the values carry over past that RPM? The split second FTC only has values to 8000, but the timing changes carry over in to 9000.
I always set up my car assuming that it only worked with the numbers (RPM range) that were present. Doing a map trace would really answer this, I can't recall what happens if your map starts at 3K RPM and you sit at idle. Does it trace to the first squares, or does it not show up on the screen at all. I don't recall. But I always went for safety. I modified my map's X axis to go to 9,500 RPM and carried the 9K settings onto that range to cover all my bases.
Bullet, how's that unplugging of the eManage and running on the stock ECU working out?
Old 04-23-2004, 05:28 AM
  #50
the trace will stay at cell 0,0 even if the actual value is lower than the settings.....
my map started at 1500 RPM and the car was idling.... Mr trace told me that I was at cell 0,0.....
Beroz
Quick Reply: Hesitation after Dyno tune with greddy?
