here are my alignment specs with Tein RA coilovers
just posting in case anyone should need this info
MY02 18k miles, this is the first alignment done on the car, went from stock suspension to Tein
thanks to jahwerx for supplying info when I had Qs
Left Front
Actual:
-0.6 Camber
6.2 Caster
0.0 Toe
Before:
-0.8 Camber
6.2 Caster
-.39 Toe
Right Front
Actual:
-0.6 Camber
6.1 Caster
0.0 Toe
Before:
-0.6 Camber
6.1 Caster
-.42 Toe
Front
Actual:
0.0 Cross Camber
0.2 Cross Caster
0.0 Total Toe
Before:
-0.2 Cross Camber
0.2 Cross Caster
-.81 Total Toe
Left Rear
Actual:
-1.4 Camber
.22 Toe
Before:
-2.2 Camber
.46 Toe
Right Rear
Actual:
-1.4 Camber
.26 Toe
Before:
-2.2 Camber
.43 Toe
Rear
Actual:
0.0 Cross Camber
.48 Total Toe
-.02 Thrust Angle
Before:
0.0 Cross Camber
.89 Total Toe
.02 Thrust Angle
Left Front
Actual:
-0.6 Camber
6.2 Caster
0.0 Toe
Before:
-0.8 Camber
6.2 Caster
-.39 Toe
Right Front
Actual:
-0.6 Camber
6.1 Caster
0.0 Toe
Before:
-0.6 Camber
6.1 Caster
-.42 Toe
Front
Actual:
0.0 Cross Camber
0.2 Cross Caster
0.0 Total Toe
Before:
-0.2 Cross Camber
0.2 Cross Caster
-.81 Total Toe
Left Rear
Actual:
-1.4 Camber
.22 Toe
Before:
-2.2 Camber
.46 Toe
Right Rear
Actual:
-1.4 Camber
.26 Toe
Before:
-2.2 Camber
.43 Toe
Rear
Actual:
0.0 Cross Camber
.48 Total Toe
-.02 Thrust Angle
Before:
0.0 Cross Camber
.89 Total Toe
.02 Thrust Angle
no, these are in no way 'official Tein' specs or anything of the sort. these are my own numbers, the results of having the alignment done at a performance shop. I am only posting this info as reference.
I dont feel any difference after the alignment, I just know now I wont need new tires in 7k miles
as far as the tein, couldn't be happier. I dont track the car at all, so the RAs are fine enough for me. no squeaks or bouncy/stiff problems - I give A+ to the preciseness of the dampers, you can really dial in on a good setting.
[QUOTE]Originally posted by payyourtoll
the rear definitely felt stiffer than the front when I put them in until I dialed back the dampening. I have them 3 clicks from softest in the back and they feel nice
thanks...i just went outside and set the dial to 2 clicks from soft on the rear...4 clicks from soft in the front...MUCH BETTER!!!!! holy shit...what a difference...i took her for a test drive..and those couple of clicks make a huge difference...
i just installed my coilovers on thurs...when is a good time to do the alignment??? what shop did u get your alignment done...i want to get the UK alignment done...let me know
Kaneda215
08-11-2011 09:16 AM
