Help - Weird sounds coming from inside the engine!!
Old 12-19-2002, 08:28 PM
  #21
yiannistsiounis's Avatar
The ECU could have started the problem but if, for example, it allowed one cylinder to misfire it may have caused some conrod damage (as chris_barry detailed and pwrmkr also noted).
However, I 'm not a mechanic:-( so I don't know if this assumption is correct. It's just that - an assumption to check for.
Good luck!
Yiannis
Old 12-20-2002, 03:19 AM
  #22
blackdemon's Avatar
Hi again guys,
Finally my S2K is out of the shop...and guess what the problem was?
Some of the IC in the ECU were damaged (showing higher values than it ought to be) - abt 15 ICs were replaced. Here's the weirder story - this damage was due to the influx of condensation into the ECU, and i guess the part which was affected were the one controlling the ignition and timing. Now the ECU's properly insulated to prevent any more future 'mishaps'.
I guess in Brunei, condensation from airconditioning is more severe due to the high humidity? I dunno...but nonetheless, the S2K's out now - cruising for bruisin. Thanks for all the comments & ideas guys, i really do appreciate them.
Old 12-20-2002, 09:01 AM
  #23
vtecskunk's Avatar
just a little fyi your motor doesnt have rocker arms those are for pushrod motors
Old 12-20-2002, 09:51 AM
  #24
Former Sponsor
Gernby's Avatar
[QUOTE]Originally posted by vtecskunk
[B]just a little fyi your motor doesnt have rocker arms
Old 12-20-2002, 09:56 AM
  #25
cdelena's Avatar
Originally posted by gernby
What do you call them then ... "roller cam lobe following see saw thingies"?
Good point. Honda calls them rocker arms, most of us do, and you can call them anything you want, but don't ask us to adopt your terminology.
jimbo_s2k
01-29-2010 08:10 AM
PathNull
06-14-2005 09:46 PM
Bigeggroll
02-16-2005 08:42 PM
Blitzspear
07-16-2004 08:29 AM
Rodion
04-15-2004 09:30 PM
Quick Reply: Help - Weird sounds coming from inside the engine!!
