Help w/ CEL After Oil Change
I got the code:
P0411 Secondary Air Injection System Incorrect Flow Detected
I have no idea where to start. Okay here is what I did. I drained the oil from the oil pan and changed the oil filter. I also installed a sandwich adapter between the oil filter and engine bay for my oil temp gauge. I had to take the 3 bolts off the airbox to move the airbox forward a little bit for me to install the sandwich adapter. Put oil (5 quart) back in and moved the airbox back. Drove the car about a mile w/out the cover for the airbox. I let the car side for about an hour and went back to start it and the light came on. It's a solid CEL.
You might have have loosened a vacuum line while moving the air box.
This thread shows you pics of the lines to check:
https://www.s2ki.com/forums/index.php?showtopic=105368
