HELP! Trying to install the Cusco X brace
how is everyone?
I was trying to install the Cusco 3 points X brace, but the problem was that I could not unbolt those 2 bolts on each side, I am not sure what size i have to use for them, i guess they are 17mm(correct me if I was wrong please)....
Also, how tight are those bolts from factory setting?
thank you very much!
i have tried the 17mm, it seems fit the bolts, but i still can not open them.... is there any trick to open them?
please help me out on this.
14 is the front one (single) and the other four are 17mm. They shouldn't be that tough to get off so they must be rusted. Spray them with some penetrating lube (wd40 or equivalent) and wait a few minutes then reapply and try to break them loose with a mallet.
