Help transmission needs to be replaced
#31
Received 1,418 Likes
I'm not sure why there is apprehension to buying a used trans from a reputable source. I have had my AP1 for 9 years. About 5-6 of those years have been with a used, low mileage, flawless AP2 trans. I upgraded for the sake of better gearing and synchros.
The used, flawless, low mileage AP1 trans that I sold is probably still running in someone's car.
The secondary shaft or output shaft bearing is most likely the culprit since the sound is vehicle speed dependent.
#32
Wait...are you sure its not your differential or tires?
I'd get the car on a lift and see if you can replicate the noise while "driving" it.
#33
Pretty sure evasive had it on a lift and they said it was coming from the transmission area, they thought it might have been the clutch at first, I replaced it but the noise is still there. When you are in the car it is coming from right below the gear shifter to me. About to pull the trigger on the transmission job, I am going to ask the rebuilders to send me back the parts that are bad so I can see what was wrong.
#34
Sorry for the late reply. Been busy with birthdays the past few days.
Here is the thread I was talking about. Please read through it all.
https://www.s2ki.com/s2000/topic/409...whining-noise/
Also, I found an OLD thread, in regards to our transmission, this morning that's quite interesting. Possibly the reason why my secondary shaft bearings are failing.
https://www.s2ki.com/s2000/topic/492...-transmission/
Hopefully soon enough, you'll figure out what the culprit is.
#35
As for the OIL problem the other post has. I sure hope that is not the case. :/ Will find out in a couple weeks, I am going to ask for bad parts back to I can report here what it was. Thanks
#36
I read the whole thread, my 02 AP1 with 56K miles has the exact same issue. I have the clutch replaced but it didn't help.
Eventually did you rebuild the transmission or install a used one? Would you mind share the cost?
#38
I hope you and others having this issue check out my thread as well! Spending a few hours to pull down the tailshaft assembly is nothing when comparing to the pain of a trans repair or replace.
https://www.s2ki.com/forums/s2000-un...lease-1181421/
#39
This is very informative. I checked out your thread and I would like to make sure my symptoms are exactly the same as yours before making the move.
- When idle, my car makes a very feint but noticeable noise from clutch/transmission, the noise goes away immediately when clutch pedal is depressed to the floor.
- My noise is louder in lower gears than higher gears. In 4th, 5th or 6th the noise is almost gone.
- The noise starts around 3-4k rpm, it only depends on engine rpm, not vehicle speed.
- I have my clutch replaced not long ago, as well as flywheel and throw out bearing, the noise still exist.
#40
