HELP! Tempermental engine behavior low/high RPM...
Hey guys, i'm new to the forum.
I noticed my car occasionally hesitates to accelerate as it usually does, and when i throttle it harder (in all gears, but noticeable most in 1st or 2nd gear), VTEC sounds strange... like its not even there at all. In fact on a flat road, the climb from 5000 to around 8500rpm takes a LONG time.... almost 4-5 seconds!!!
Plus there's just no 'ooomph' feeling at all... AND THEN, i'll try WOT again sometime later, and it'll run as it should in normal fashion.... Everything is fine with the car: healthy, no mods, no CEL/MRL, consistent oil change/91 octane pump. and I don't push the car until engine temp = 3 bars.
i've tried the "MAP WHACK", then after that it ran fine after that.. was relieved for a little bit, but it'll go back to acting weird again. Also I noticed the times it runs 'crappy' idle revving is strange... car will vibrate for about 2 seconds, and swing back to normal.
Anyone have any ideas as to what the problem is?
Well, to me it sounds like you have a cracked on sinkin' valve retainer. I could be wrong but thats just my opinion. You should have someone take a look at it or you could do it yourself its not hard to spot just be meticulous.
Hey that happens to my car as well...
I also did the MAP whack trick & reset the ECU and it runs fine but then afterwards when it idles it kinda shakes the car
if anyone knows what could be some possible causes i too would be interested..
thanks guys
thanks guys
Originally Posted by akim711' date='Jan 28 2005, 02:06 AM
xviper... so you think its a bad connection in the MAP sensor?
i believe that TSB is a simple clip that keeps the harness more secure correct?
https://www.s2ki.com/forums/index.php?showt...ensor++problems
(U.L. is a well known and trusted S2000 tuner.)
just wanted to add that i have had the MAP sensor changed as well as putting in new spark plugs that have been gapped correctly and my car still idles rough and shakes the car left to right at times & when on idle i can hear a clonk from the left front of the car
