help from someone with an ap2 service manual
Can someone with an ap2 service manual look up the factory ride height measurements in the wheel alignment section? I have an ap1 manual but i dont know if its the same. on the ap1 manual its page "18-5" under the wheel alignment section and talks about the distance from the center of the A-arm bolt to the ground.
Thanks in advance
Thanks in advance
Page 18-7:
" Height:
Front 192-202 mm (7.56 to 7.95 inches)
Rear 206-216 mm (8.11 to 8.50 inches). "
This is for 2004 through 2007 OEM sized wheels/tires.
" Height:
Front: "The height from the ground to the center of the head of the lower arm's front adjusting bolt."
Rear: "The height from the ground to the center of the head of the lower arm's rear adjusting bolt."
DaPhatty
03-01-2012 10:55 PM
QuagmireS2k
15
09-19-2011 10:34 PM
