help: Removal and replace Rear knuckle and boot
I am in the process of removing the rear driver side knuckle and replacing it due to a minor accident that I was invovled in. The boot was torn along with the lower control arm being bent. I know how to replace everything besides the boot? .. any Ideas on how that is done? I have never had to replace this before?
edit:
https://www.s2ki.com/forums/index.php?showt...367&hl=cv+joint
I think i found out how, is it the same considering it is on a different side? anyone know IF i can just buy the boot?
edit:
[SIZE=7]http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=S2000&catcgry 2=2000&catcgry3=2DR+S2000&catcgry4=KA6MT&catcgry5= REAR+DRIVESHAFT
Try the above website. You can save money on your control arm here too. If you need to get a knuckle cheap, try:
http://www.slhondaparts.com/
Let us know how your repairs go. I would worry that shock to the rear strong enough to break the knuckle and bend the lower control arm might damage the differential, especially the pinion and ring gears..
Administrator
edit:
edit:
http://www.gofastlab.com/s2ki/home.php?cat=30
Originally Posted by lamvu,Dec 18 2004, 07:50 PM
I am making the repairs tomorrow, How would i go about making the inspection?
