Help: Recovered stolen - need to identify broken piece
Key ignition got busted and they also broke an electronic piece which I don't know what it is.
Need help to identify so I can order part. thanks
Also, I found a chip board on the carpet. Don't know what that is. I attached the photos.
4 wheels, 2 seats, ecu, radio, steering wheel were taken.
I'd say it is the plug that goes into the ignition key switch, there is supposed to be one connector that goes into the immobilizer receiving unit that is a 5p connector, and one connector that goes into the ignition key switch that is a 7p connector just below it. It looks like the connector just above it is the one for the immobilizer receiver unit so that one should be the one for the ignition key switch. As the ignition key switch appears to be destroyed I'd say the circuit board on the ground came from the switch - just a guess. sorry about your loss.
Thanks. I'll look into immobilizer receiving unit.
Yeah, I ordered an ecu with key and ignition unit from ebay already. Now, I just need that broken piece.
animal
25
05-25-2010 04:30 PM
