Help! rear caliper piston won't compress
Old 09-01-2004, 08:07 PM
drewchie's Avatar
Default Help! rear caliper piston won't compress
I have the rear caliper off the car, but I can't get the piston to compress so I can get it back on over the new pads. The brake line is removed and the valve is wide open
Am I forgetting something? Any suggestions?
Thanks
drewchie is offline
Old 09-01-2004, 08:10 PM
God
God's Avatar
what are you using to compress it?
God is offline
Old 09-01-2004, 08:11 PM
drewchie's Avatar
Just a thick pair of plumber's pliers (I forget the correct name)
*I think it's called a channel lock (sp)
same problem on the other rear... the fronts compressed easy.
(yes, the parking brake is off )
drewchie is offline
Old 09-01-2004, 08:20 PM
God
God's Avatar
are you using something across the piston to insure you are applying even pressure across the surface of it?
God is offline
Old 09-01-2004, 08:22 PM
drewchie's Avatar
Not really, the channel lock is big enough to reach across the piston flat. Like I said, the fronts were no prob. , just the rears.
drewchie is offline
Old 09-01-2004, 08:23 PM
Slows2k's Avatar
You DO NOT compress the rear caliper piston with pliers. The piston must be turned clockwise back into the caliper. A large flat blade screw driver works in a pinch. Hopefully you didn't damage the piston or caliper.
Slows2k is offline
Old 09-01-2004, 08:26 PM
drewchie's Avatar
oops... thanks
(the piston looks ok)
drewchie is offline
Old 09-01-2004, 09:04 PM
alexf20c's Avatar
At least you didn't use a giant C-clamp, or better yet, a 5000lb press.
alexf20c is offline
Old 09-01-2004, 09:12 PM
rlaifatt's Avatar
A large flat file works well also. Make sure you line up the "+" slots perpendicular to the caliper so it will fit over the stud on the pad.
rlaifatt is offline
Old 09-01-2004, 09:57 PM
mikegarrison's Avatar
Now that you have solved your emergency, before you do this again you should go to the store and buy a disk brake piston tool. It will make the job easier. Looks like this:
http://store1.yimg.com/I/rodi_1806_70175017
You just put the side with four tangs into the four slots on the piston, then use a ratchet with an extension bar to turn it.
mikegarrison is offline
Quick Reply: Help! rear caliper piston won't compress
