HELP QUICK PLEASE! Broken VTEC Sensor!
Broke the sensor off when getting the oil filter undone. I think it is the VTEC pressure sensor? Here are a few photos showing all damaged parts. If somebody could be kind enough to give me the part number for the parts (2 parts ?), it would be awesome. I was hopping to be able to find it on hondapartsdeals.com, but I can buy it from anywhere, whatever is the quickest.
Thanks a lot in advance!!
Is your plug OK? The sensor part is:
37250-PCX-A02 016 001 SWITCH ASSY., VALVE TIMING OILPRESSURE
61.70 43.19
Found it here:
http://www.hondaautomotiveparts.com/...=CYLINDER+HEAD
61.70 43.19
Found it here:
There is not one. I will check and see if I have that plug on my junk harness. You have to replace engine harness yo get that part from the dealer. If I do have that plug spare you will have to use a small pin to release the locks from each of the pins and push them out the back.
Im somewhat sure any vtec oil pressure sending unit off any older honda vtec motor will work? Correct me if im wrong I do however have one (green plug) and the connector as well id get ya have both for cheap if someone can verify that they will interchange i can help ya out with the parts for cheap. I know that most the two wire connectors will all work.
I have purchased the plug and sensor from an S2Ki member.
And yeah, when I called the dealer they said that I would have to order the whole harness for ~$500!
Thanks again for the help everyone!
I broke the pressure switch side of the clip on mine too while doing a valve job. Does anyone have one they're looking to sell? It's part number 37250-PCX-A02. Thanks.
