Help please with Ballast/HID problem (Video clip included)
my driver side HID started acting up last night.. dont think its the bulb problem as bulb would turn pink before getting fried..
i included a video clip to show what happens. When you turn the light switch on, the HID badly flickers and the DRL/Highbeam bulb slowly starts going on brighter and brighter and both shuts off (wtf?). Obviously the highbeam switch is off, and i disabled my DRL so i dont really know what the deal is..
passenger side hid lights up perfectly fine, although the highbeam/drl bulb lights up slowly and turns off when igniting like the driver side headlight... as far as i know this is not normal...? (you can see it in the vid)
possibly a fried ballast? or loose connection with the harness/wires?
if i need a new ballast, i might just get a set of ap2 headlights with ballasts and bulbs since the passenger side will probably go out anytime soon as well.. i really hope not though, dont want to spend money right now
http://www.youtube.com/watch?v=jY_Krzzwm6c&feature=plcp
yeap.. dont know whats going on
Check out Modifry's page at http://www.modifry.com/freebies/old/zenon/index.htm cause your issue sounds very similar to his article about the S2000's "funny fuses"
oh wow.. sounds like i got a blown fuse than..
im at work so im gonna take a look at the fuse on my break asap.
now.. i wonder why the fuse blew? im a sucker when it comes to electrical stuff
defently its not the ballast, if it was there would not be any light, obviously its not a fuse either if it was then both headlights would be doing the same thing, it can either be a loose connection or most defenetly just the light bulb done, in case it is the light bulb no need to worry you can buy 2 bulbs for 20 bucks of js2k.com but its going to be more blueish(6k) but its still as bright, i actually like it better.goodluck
