help parking and tailight switch won't work
you know when you turn on the parking light switch on, the parking light, instructment light, and tailight should turn on. but when i turn it on, none of the light works but when i go out and press the unlock and lock on my keyless it turns on like it suppose to
nope it was fine today until i drive pass a railroad track which made my instructment light turn off and when i got home i realize that the paarking light and the tailight isnt on either
well i am guessing that you know what the manual say for them, but for good measure i'd check anything light related.
but with it happening right ar you went over the tracks i would say to look under the dash and around the steering area for a loose wiring harness.
if you start to dig into the wheel though be careful not to set off the air bag
Check your kick panel on the left side, it should have the diagram of the fuse that are underneath there. I would believe you have a loose wiring harness, since when you went over the rail road track and your instrument lights went out.
