Help no clutch pedal
Hi guys, I have a problem with the S2K, my clutch pedal was stiff so I decided to grease up the rod in the slave cylinder but as I was doing that the slave was dripping a little bit of fluid out and now I have no clutch pedal, can anyone help?
Received 1,377 Likes
Did the slave cylinder pushrod slip out of its cup when you tried to install it? Or did you do something crazy like dislodge the clutch fork from the bearing?
Have someone hit the pedal while you look at the slave cylinder.
laserred02
11-28-2012 07:12 PM
hokiemax
09-14-2008 10:00 PM
