Help needed! Engine broken at 165 MPH
Old 06-28-2004, 03:30 AM
  #21
RACER's Avatar
Wow, I didn't know that the compression was that much.
Old 06-28-2004, 04:51 AM
  #22
kstokell's Avatar
Does anyone know if the bottom end bearings can be replaced without removing the engine?
Old 06-28-2004, 05:53 AM
  #23
beroznikmal's Avatar
Yes this can be done...
you will need to remove the oil pan and the gerdle (spelling)... and I think the oil pump...... then you will see the crank and the rods....check your cylinder walls for scoring while your down there...
I would first check the oil pan to see if you have any bearing material.... a blind man could spot bearing... it is the only thing in your engine that is copper...... if you got copper you got some bearing...not good.......
if you dont got no copper than I would test for play of your rods and check the clearence of yoru main bearings ..... all measurements are in the manual....
A new bottom end (short block) from Honda can cost anywhere from $1900 - $3000 depending on the dealer......
a new crank + bearings + oil pump = $1200...... for ordering new bearings (main and rod) you should check what number is in printed on your block and the rods..... the block should have 5 letters..... one letter for each main bearing..... each crank should have a number..... I think its 1 - 5.... remember these letters and numbers when your ordering the bearings.....
If it is bearing you will also have to drop your tranny..... (while your at it you might as well upgrade your clutch).....
Hope this helps......
Beroz
Old 06-28-2004, 05:55 AM
  #24
oh another thing you would need to drop is your oil pick up...... u can also check in there to see if you have any bearing material....
beroz
Old 06-28-2004, 06:29 AM
  #25
kstokell's Avatar
Thanks for the help Beroz.
Kevin
Old 06-28-2004, 06:38 AM
  #26
Former Sponsor
Gernby's Avatar
I have just found that the compression should be 200 > 250 PSI with a difference of no more than 20 PSI between the cylinders.
Can anyone confirm this?
That sounds right.
Old 06-28-2004, 07:56 AM
  #27
kstokell's Avatar
I've done a little more investigation.
I've removed the plugs and valve cover, the top end looks OK no broken springs or anything.
All the plugs looked great, except Cyl 4. (nearest the driver)which was a little sooty as though it was running slightly rich.
Maybe this pionts to a problem with the piston in Cyl 4. and the noise I'm getting is piston slap.
What do you all think?
If it is Cyl 4. do I have to replace the short block, or is there another solution?
Kevin
Old 06-28-2004, 09:12 AM
  #28
If you scored the was you will definatly have to replace the block...... maybe oil pump...... I would drop the oil pan and proceed from there.....
Old 06-28-2004, 12:57 PM
  #29
Former Sponsor
Gernby's Avatar
Why couldn't the scored block be honed?
Old 06-28-2004, 03:06 PM
  #30
RACER's Avatar
The cylinders are sleeved.
Quick Reply: Help needed! Engine broken at 165 MPH
