Help.....Need advice!
I must decide by tommorow what clutch to install on my 2003 S2000. The only current mod i have is an exhaust, however i have a turbo in the works. I am going to be using the toda flywheel, and need suggestions on the clutch. I can get a exedy hyper single for a good price as well as a clutchmasters stage iV.
WOULD THE CLUTCHMASTERS STAGE IV BE OK FOR DAILY DRIVING UNTIL I GET MY TURBO UP AND RUNNING?
Would this clutch be too strong for my diff?
Any help is urgently needed and much appreciated.
-Matt
-Matt
IMO, the stage IV is a little much for daily driving... my old Import Tuner CRX had a Clutch Master's stage IV and lemme tell you, my left leg got really buff... ....plus its a bitch to drive in traffic..
good luck, let us know what you get and how you like it...
I have a solid carbon disc and it's good because the carbon slips a little more than the organic. This way you get both: the race feel of a solid disc and you don't get the chatter that's normally associated with solid discs.
Just my $.02
Just my $.02
Thanks for your input. I unfortunatley had to make a decision before reading this info. Between the searches that i did and speaking with steve @evolution i decided on the clutchmasters stage IV, and the Toda light weight flywheel. Merlin( on all the evolution autosports group buys is running this same setup. It is "streetable", but i'm sure will be worth the leg workout when it finally sees boost! Thanks again; I'll keep you updated
-Matt
-Matt
riceball777
11-29-2014 05:22 PM
