Help My Smoking Turbo S
So we just installed a Speedcraft turbo kit ...everythin'g's cool but the damn boost controler won't work ( profec b...help on seting up that also ... ) and it smokes between shifts it dosen't smoke on idle or when we start it but right after boost it puffs smoke...? HELP US PLEASE!!!
well we know i'ts running rich...cause of the FMU. could that cause white smoke? it dosen't smell like smoke ususally smells though...it that cause we're using Mobil 1 full syn.?we haven't done a compression check but thanks for the good idea! anyone else out there with some theroies?...let me know thanks
-YS
you usually will smoke between shifts if your map sensor is seeing boost. look at your check valves or missing link, i suggest using a missing link if you dont have one already
i know this aint no porsche, but when i follow my bros porsche turbo, everytime he shifts it shoots a big cloud of black smoke, his is highly modified with K-29 turbo and a big intercooler and no cat, header exhaust, but alot of smoke on shifts is fine i think its prolly just your waste gate.
well we all know what coolant smells like and i'ts deff not that.! we ran a compression check/leak down test last night and they all were verry close to 225 in each cyl! so i'm not leaking anywhere? we haven't tried the map sensor think i know we had to replace an o ring in our missing link with a "close " one so mabey a little is getting by...we're gonna hook up the "in " on our Vafc to watch what its' reading...thank everyone for their ideas!
ok, dumb question, but don't the s2000s run a little rich anyway. I've noticed mine is a little smokey, but so are many of the others I've seen. Maybe I'm wrong...
