HELP ME PLEASE
HELP ME PLEASE
Hi all...i recieved my car not even 48 hours ago...i done + - 260 km in it but one friend of mine discovered that the car is leaking oil from the part that ends the gearbox and begins the propeller shaft...
Please help me...is leaking too much....
does someone knows what is happening...
Thanks in advance,
Dennes
Thanks in advance,
Dennes
Thanks Xviper...Thanks Billman...
does the gearbox must be removed in order to change the seal
or only the propeller shaft
thanks again,
Dennes.
Product No. Illust.
No. Reqd.
Qty. Description Color List
Price Our
Price Click to Buy!
205900 001 1 PLATE, OIL GUIDE SETTING NO COLOR 3.85 2.89 Qty:
207286 002 1 SCREW, SEALING NO COLOR 3.84 2.88 Qty:
205901 003 1 STAY, HARNESS NO COLOR 7.70 5.77 Qty:
205902 004 1 CLAMP, HARNESS NO COLOR 3.79 2.85 Qty:
374099 005 1 COVER, RR. NO COLOR 262.60 196.96 Qty:
1321415 006 1 SHAFT, SECONDARY NO COLOR 129.11 96.83 Qty:
1356952 007 1 FLANGE, COMPANION NO COLOR 44.04 33.02 Qty:
205906 008 1 SHIM, A (68MM) NO COLOR 5.13 3.84 Qty:
205907 008 1 SHIM, B (68MM) NO COLOR 5.13 3.84 Qty:
205908 008 1 SHIM, C (68MM) NO COLOR 5.13 3.84 Qty:
205909 008 1 SHIM, D (68MM) NO COLOR 5.13 3.84 Qty:
205910 008 1 SHIM, E (68MM) NO COLOR 5.13 3.84 Qty:
205911 008 1 SHIM, F (68MM) NO COLOR 5.13 3.84 Qty:
205912 008 1 SHIM, G (68MM) NO COLOR 5.13 3.84 Qty:
205913 008 1 SHIM, H (68MM) NO COLOR 5.13 3.84 Qty:
205914 008 1 SHIM, I (68MM) NO COLOR 5.13 3.84 Qty:
205915 008 1 SHIM, J (68MM) NO COLOR 5.13 3.84 Qty:
205916 008 1 SHIM, K (68MM) NO COLOR 5.13 3.84 Qty:
205917 008 1 SHIM, L (68MM) NO COLOR 5.13 3.84 Qty:
205918 008 1 SHIM M (68MM) NO COLOR 5.13 3.84 Qty:
205919 008 1 SHIM, N (68MM) NO COLOR 5.13 3.84 Qty:
205920 008 1 SHIM, O (68MM) NO COLOR 5.13 3.84 Qty:
205921 008 1 SHIM, P (68MM) NO COLOR 5.13 3.84 Qty:
205922 008 1 SHIM, Q (68MM) NO COLOR 5.13 3.84 Qty:
205923 008 1 SHIM, R (68MM) NO COLOR 5.13 3.84 Qty:
205924 008 1 SHIM, S (68MM) NO COLOR 5.13 3.84 Qty:
205925 008 1 SHIM, T (68MM) NO COLOR 5.13 3.84 Qty:
205909 009 1 SHIM, D (68MM) NO COLOR 5.13 3.84 Qty:
205926 010 1 NUT, HEX. (27MM) NO COLOR 3.74 2.81 Qty:
205927 011 1 WASHER, SPRING (27MM) NO COLOR 3.95 2.97 Qty:
205928 012 1 BEARING, BALL (31X55X13) NO COLOR 16.22 12.16 Qty:
205929 013 1 BEARING, TAPER (41X68X20) NO COLOR 31.16 23.37 Qty:
205930 014 1 BEARING, TAPER (35X68X19) NO COLOR 31.16 23.37 Qty:
205931 015 1 OIL SEAL (40X60X9) NO COLOR 6.98 5.23 Qty:
205932 016 1 O-RING (28X2.6) NO COLOR 2.35 1.75 Qty:
205933 017 1 RING, BACK-UP (28MM) NO COLOR 2.59 1.93 Qty:
3615 018 6 BOLT, FLANGE (8X40) NO COLOR 0.87 0.65 Qty:
26044 019 2 BOLT, FLANGE (8X50) NO COLOR 0.90 0.68 Qty:
what this parts must be replaced
Thanks for your help
thanks again,
Dennes.
Product No. Illust.
No. Reqd.
Price Our
Price Click to Buy!
At the very least, you are looking at replacing part #15 in the picture you put up. This can be done with the tranny still in the car. However, if like Billman said, the adjacent surfaces are nicked, you are looking at replacing those, too.
Thanks Xviper...
i called to the honda dealer and the engineer start to say that was me that hit something ...i told him more than 3 times that the car is in perfect condition and i didnt hit nothing... i will wait to see what he will say
thanks for your help,
Dennes
Dennes
Maca
08-24-2002 08:49 PM
