Help me identify the source of this oil seepage
Car is a 2005 with just under 150k miles on it. Seems like I'm always getting some oil seeping somewhere and its making a bit of a mess of the engine. Back in June of 2017 I replaced the VTEC solenoid gaskets. I used this: and the OEM seal w/ the filter in it. I'm going to be installing the PTuning turbo kit very soon, but want to make sure this is all cleaned up before hand. Thank you.
Definitely replace the vtec oem gasket with factory oem gasket from honda. ALL other gaskets for thr vtec solenoid seem to bee to thin even the best of brands have beeb reported as too thin. Stick with oem for gaskets on the s2k.
Honda doesn't make the gasket from that Amazon link though, from what I can remember.
As far as the turbo manifold is concerned, its the P-Tuning manifold so I'll still be able to see the front of the engine easily.
Maybe it was those gaskets leaking from age, and the new ones are still leaking from some install issue (not a clean surface, ood gasket material, faulty gasket, etc).
Looking at where the oil stains are, the other thing that occurs to me is the tct grenade pin removal port bolt.
