Help me find my leak.
Originally Posted by Doug1627,Nov 21 2007, 09:08 AM
OP, with the vehicle off push the gas pedal fairly hard and see if the pedal sinks. If it is slowing sinking you are losing brake fluid.
Originally Posted by Doug1627,Nov 21 2007, 08:08 AM
OP, with the vehicle off push the brake pedal fairly hard and see if the pedal sinks. If it is slowing sinking you are losing brake fluid.
He mentioned that he just replaced his clutch (which is a fact that should've been mentioned in the original post
![rolleyes.gif](https://www.s2ki.com/forums/images/smilies/rolleyes.gif)
my thoughts exactly...
he didn't mentiono he just replaced his clutch...and the leak can be seen around the transmission housing. haha
but regardless...if we just throw out all the possibilities...the seal is one of em.
time to open up that tranny again.
Originally Posted by mxt_77,Nov 21 2007, 06:27 PM
Not necessarily. That's generally the symptom of a bad master cylinder. The seals go bad, so it's only leaking internally, but it's still in the system. There will be no external evidence of a leak, and the level in the reservoir will not drop.
), so things that are touched by that procedure are where he should start looking.
