Help me find my leak.
Old 11-19-2007, 11:42 PM
attack666's Avatar
Default Help me find my leak.
Ive noticed i got a leak a few days ago but i dont know where the problem is, its the brake fluid thats leaking but i cant find where is it from,the level in my Clutch master cylinder and brake Master cylinder isnt decreasing or anything..im just lost i dont know where the leak is from
took the car to the car wash the other day and i noticed its from the engine bay and was dripping all the way on the trans housing.
just tell me where to check and what to check as im to afraid to drive the car alot.
Old 11-20-2007, 01:10 PM
jyeung528's Avatar
how do you know it is the brake fluid?
Old 11-20-2007, 01:27 PM
f23power's Avatar
your going to have to be more detailed. color of the fluid? is it constantly leaking? if it is then you should know by checking all the fluids. it can be just as something as condensation from you a/c
-a
Old 11-20-2007, 02:37 PM
2poor2mod's Avatar
its hard to beleive that the brake fluid is leaking if the levels in both of the master cylinders are remaining the same. my advice is to search around the engine bay top to bottom with a flashlight and if you think it is brake fluid have someone apply the brake pedal and clutch pedal while you are looking to confirm where the leak is coming from if it is brake fluid. if not continue the search
Old 11-21-2007, 12:53 AM
attack666's Avatar
color of the fluid?
-a
its yellow-ish
yes its constantly leaking
jyeung528..cause it smells like the brake fluid and the colour is the same.
2poor2mod..I will do that thanks for the advice
though i tried searching where its comming from but still no luck.
Old 11-21-2007, 01:35 AM
iam7head's Avatar
well, you can clean everything and left the car over night with a clean cardboard so pinpoint the general location of the leak.
check the slave cylinder, if it's from the tran's housing it could very well be the rear main seal
Old 11-21-2007, 02:27 AM
attack666's Avatar
it could be, cause i have recently changed my clutch so maybe something went wrong while putting the trans back up.
i will try the cardboard seems a good idea thanks
Old 11-21-2007, 03:03 AM
RACER's Avatar
the rear main seal
Old 11-21-2007, 05:08 AM
Doug1627's Avatar
OP, with the vehicle off push the brake pedal fairly hard and see if the pedal sinks. If it is slowing sinking you are losing brake fluid.
Old 11-21-2007, 05:21 AM
RACER's Avatar
[QUOTE=Doug1627,Nov 21 2007, 06:08 AM] push the gas pedal fairly hard and see if the pedal sinks.
Quick Reply: Help me find my leak.
