HELP! Locked Trunk
HELP! Locked Trunk
Locked my trunk. And no matter what I try it won't open. Is remove the interior panel and get to it is the only way???????? and what panel I have to remove????
Explain a bit more? How did it get locked? don't you have a key? The open button not working? Do you hear the lock open when you push the button?
I know what it would take to get it open from the front, but it is no easy task. Even in a stripped car it is a reach. So
umm flip down your center console there should be a button to push that opens up the trunk.. otherwise have you tried putting your key in the keyhole on the back and opening it with the key??
Originally Posted by NFRAP1,Feb 8 2007, 10:34 PM
way to point out the obvious!
Originally Posted by Ustemuf,Feb 8 2007, 10:35 PM
well if his trunk is locked i dont see what other way to open it other than to do either of the following. his post is kind of confusing.
