Help installing gauges
Hi All,
I need your help please I'm trying to install Defi oil temp and pressure gauges and i have not got a clue were the oil pressure switch is to tap into and were the hell do you put the oil temp sensor.
Thank you
DB
Thank you
DB
In case you want to know, Xviper's excellent writeup may be helpful:
http://forums.s2ki.com/forums/showthread.p...=&postid=999038
Thanks Slalom, for putting up that link. It will certainly give him the idea. I was reluctant to put it up because with both oil pressure and oil temp, "ganging" it up at the stock pressure sender won't work as well.
I also did one for the Defi gauges too:
http://forums.s2ki.com/forums/showthread.p...&threadid=99530
vaamntxoovzeb
08-24-2010 09:18 AM
