Help install ground controls?
I have a set of used ground control coilovers that's coming in this week..just wondering if anyone can give me some instructions after stock suspension is off the car.
Andrew
Andrew
https://www.s2ki.com/forums/index.php?showtopic=303417
This DIY is basically the same thing as installing ground control sleeves.
Don't use the OEM dust covers, if you are sticking with the OEM shocks. The will get jammed aroung the threads of the sleeves. I made this mistake once on installing for someone and he had to come back for a fix. Basically I had to do the same job twice. I also recommend setting the perch in the middle of the range of adjustment to begin with. You'll be able to go up or down from there, but it is a good starting point.
Again if you are re-using the OEM shocks you'll need a spring compression tool (Autozone/Kragen) to take the OEM suspension apart safely.
Good luck and plan on half a day, minimum.
-Hockey
-Hockey
1 Post
-Hockey
-Hockey
If you have the proper tools and the knowledge of how to change suspension then plan on 2-3 hours
Originally Posted by KeithMajkasays,Aug 8 2008, 01:34 PM
1/2 day?!
Not everyone is as proficient.
-Hockey
barrett4bama
08-11-2010 02:12 AM
ASpec818
06-01-2009 11:20 AM
