HELP! i need a s2k doctor
![Thumbs up](https://www.s2ki.com/forums/images/icons/icon14.gif)
hi guys,
i just changed my stock radiator to koyo aluminun radiator,
the weird thing is that when i set my a/c all the way to the right(heat/red).
i still get cold air blowing, even after 40mins of driving, its still cold air blowing!?
what could cause this?
another is my engine temp keeps going up and down,
could the wrong coolant cause this?
is there a temp control device that could be malfunctioning?
its annoying to keep pulling over, i dont know if im overheating or not.
any help would be appreciated
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
xviper: vapour lock in the cooling system? could the dealership know how to fix this?? im thinking of just bringing in the car today after work.
*how does vapour lock happen?
If you're a "handy kinda guy", you can do this yourself using the DIY I wrote up on the coolant change, flush and bleed:
https://www.s2ki.com/forums/showthread.php?s=&threadid=86811
Just scroll down to the part where the bleeding starts.
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I've found even if you follow the manual to the T, you will still have air in the system. It can take up to 15 miles or more and the car may start to overheat. It takes some trial and error to get the air out, opening the front bleeder with the engine running helps alot.
xviper: so i should run the motor while "bleeding" out the air pocket?, do i need to unscrew both bleed screws (bottom/top) or do i take it one by one?
DVSwetwilly: my head gasket does look like its leaking, could be the problem.. ill have to get it checked by honda
