Help!! I cant figure this noise out
im hoping something is just lose, no luck in finding it yet LOLOL
Received 1,744 Likes
Unless Billman can chime in with exactly the noise location, I would check more than just bolts. Something like the battery shield could do that, mounting bracket edges, etc.
hopefully he see’s the post and does chime in haha, I’ve been looking everywhere, under the car all that. The noise brings me to the crank pulley area every time. Going to take another look tomorrow
I have experienced those same shaking/squeaky noises on other cars and they are not always easy to find. Most times when I finally find them, it is by placing my hand on the part causing them and hearing it stop. I chased one on another car of mine and found it when I leaned over the fender one time (it was the fender bolts in that case). They can definitly be a pain! But it does sound a lot like something shaking and moving around against something else. Good luck!
I'm having the same issue! Only had this car 1.5 months but mine started after installing the K&N intake. So there's definitely something loose but every nut and bolt in the kit is as tight as can be. I've checked three times. All lines are setup correctly as well.
My similar sound only heard at low speeds in 2nd or 3rd gear under light throttle. If you speed up it goes away.
Have you replaced or unbolted anything with gaskets? Intake manifold or throttle body gaskets for example? Also take video of the noise while shutting off the engine thatll help to see if its a vacuum or mechanical noise.
