Help!! I cant figure this noise out
Spoiler
Any one ever experienced this squeaking/squealing noise before?? Only Happens when engine is warm (does not happen on cold start) and being started warm also can be heard most of the time at idle but not as much & when releasing into first gear. (Video of both scenarios attached)
Took the serpentine belt off and started it and same noise, jacked the car up and the definitely sounded like it was coming from the CRANK PULLEY, replaced it and same thing but the noise is more just coming and going now and not there all the time. Brought it to a trusted mechanic and he could not source anything of the noise either.
Any help or advice is appreciated, thank you. LINK TO YOUTUBE VIDEO BELOW....
BUMP, I replaced the tensioner pulley bearing, idler pulley bearing, found an exhaust leak and had it fixed. The noise is still there. Serp belt is in good shape and shows no sign of wear. ANY Help is appreciated. It’s getting annoying as hell
That to me is a squeak from something rattlingmoving. It smooths out and stops at higher rpm it sounds like and starts up again when starting to accelerate. So I would look for items that could move when the engine moves. The aftermarket intake maybe? Lay your hand (with gloves on if stuff is hot) on things like the intake and other items that could be moving around and see if the sound changes/stops. Could also be fender mounts that are vibrating with engine vibration causing them to squeak if they are a little loose.
the noise sounds like it’s coming from the crank pulley area for sure, it’s been a tough one for me, the sound doesn’t get better or worse and it comes and goes.
also check radiator mounts and anything connected to the radiator. Those sounds would possibly sound like they were in that same area.
Received 1,744 Likes
I think it is something loose, particularly a bolt rattling on something else that magnifies the noise. As you change rpm you reach the resonate level causing a real increase in vibration of the affected part.
