HELP how to adjust the convertible frame?
You have a MY00 with a retro-fitted top well out of any warranty and with a fitment issue not related to the factory-assembled top/frame. I would not (and this is *definitely* speaking from experience here) expect Honda to honor the above TSB. Its not intended for situations such as yours and mine.
Well, you've exceeded your 3yr/36K mile original warranty. Unless you have an extended warranty, Honda will probably only consider it as a Good Will gesture. You'll want to go through Customer Care
I dont feel like making a new thread for this so I'll ask here since it is closely related. Does any of your softtops not line up perfectly when closed? Mine is a little to the side and I have to kind of line it up with the hook\locker thing when I close it up.
u will see little bolts with rubber cover....
u need to unlock the thread behind to be able to adjust
this allows u to adjust how far and which side it will sit when it is allthe way up
hope this helps
i have ordered the Ht striker so i will see what those things can do about my problems
