HELP how to adjust the convertible frame?
ever since i swapped my old top with new one
there is big gap between my soft top and windshield frame which causes for wind to come between and it gets loud as i go high speed
i need to kill that gap
anyone know how?
anyone know how?
Originally Posted by xviper,Apr 14 2005, 12:25 PM
I see you have a MY 2000. You need to get the hardtop windshield strikers and Loctite them in. This should resolve your problem.
Originally Posted by Ooalloems2koO,Apr 14 2005, 03:15 PM
THANK YOU IM GONNA ORDER THOSE
Can you please give a lil more information for what i should do or need to get? and how this will fix the problem??
As i have the same problem... The noise is loud - as if my car is a full time convertible
Thanks
Originally Posted by CIVIC-R,Apr 14 2005, 08:20 PM
hey,
Thanks
Thanks
http://hardtopguy.com/store/customer/produ...0&cat=92&page=1
Originally Posted by CIVIC-R,Apr 14 2005, 09:20 PM
hey,
Thanks
Thanks
Look at the thing in the windshield that the softop latch hooks onto. It is a plate that has 3 mountings holes. You need the left and right one.
I don't recall the exact year, but the later ones came with the heavy duty strikers from the factory even if you don't ever get a hardtop.
You should check with the dealer. Some have been known to do a TSB by providing the HD strikers.
You need item 62 shown here:
http://www.slhondaparts.com/browse.asp?Mod...&ViewParts=true
Just make sure you get the one for the later cars or for the hardtop.
Originally Posted by Ooalloems2koO,Apr 14 2005, 09:39 PM
One day I'll buy the real deal from hardtopguy as advised here. But I'm a tinkerer so when I'd experienced the same increased noise subsequent to ragtop conversion, I decided to take action. I removed my striker plates, used them as a template against some extra vinyl flooring I had in the garage and then using 2 layers, I screwed the striker plates back in. Reduced noise signficantly...but there was still a liiiiitle bit more noise left to deal with... Ultimately, added a little snippet of black tube hose and slipped the hook through the little snippet. That "added thickness" really did the trick. And a foot of hose from the hardware store has a lot of snippets in its lifetime...when the first set wears out, replace them .
Again, the above suggestions are for the penny-pincher in us. The '02+ hardtop strikers that hardtopguy.com offers is the best solution if you don't want to be bothered with a DIY project requiring more than a screwdriver.
- Dave
- Dave
