Help with heater!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Hello my name is javi, I recently installed the hondata intake manifold gasket but now my heater dose not work.... Any one have any ideas to why? Also im new on the site... Thanks in advance
Make sure you retorque the bolts on the intake manifold as the gasket will get crushed over time and will eventually start to leak. To me, the negatives outweigh the gains for this mod.
Make sure you can get finger burning heat out of the vents. If not, you risk cooking your motor.
Billman recently posted in another thread that with air in the cooling you can be fine for a long time then one day the air will find its way to the wrong place and you overheat. He stated with the S one overheat can cook your motor. Warp head, damage block, or blow head gasket.
He said if you aren't getting finger burning heat from your vents, you still have air. Take care of this before it burns you.
JohnnyP912
Member S2000 Classifieds and For Sale
12-01-2009 10:48 AM
druid1390
11-30-2009 09:58 AM
