HELP! hard to shift into any gears
hey guys
my car is a 2001 and it is really hard to get into gears. I bleed the clutch, changed transmission fluid to honda MTF. Like it is impossible to get the car in reverse, so what i do is cut the car off, put it in reverse then start it back up so i can back out my drive way. everything shifts smooth and perfectly when the car is off, but once its started hot or cold i feel like i have to slam the shifter into gears for it to go. Any suggestion on what it could be? clutch? tranny is bad? but if the tranny is bad it wont even engaged in gear when the car is off right?
cliffs: hard to shift in any gear, have to cut the car off to put in reverse.
hot or cold condition its the same
what could cause my s2000 to not engage in gears normally and smoothly?
thanks for the help in advanced guys
Does it grind going into gear or can you not get it in gear at all? I had a piece of the clutch disk break off into the pressure plate about 3 laps into a track day last spring. As I rounded the track it got harder and harder to get into gear. WHen I parked it it was impossible to get into a gear, I had to turn it off and start it in gear and even then it was quite hard to shift into the next gear. Just a stab at the darke here, I'm sure someone else with more drivetrain knowledge will chime in here.
Does the car want to move when you're stopped, even though the clutch pedal is on the floor?
If so, it's a dragging clutch (incomplete disengagement). Could be due to air in the hydraulics, or something mechanical in the clutch itself (as per slipangle79).
If the car has no tendency to move when stoped, then then the problem is something in the transmission.
I'm not sure about that S2K, but in my Integra I had this problem and it turned out to be the clutch master cylinder, its under the dash and it was leaky and I just replaced it and bled the clutch and tada! it was fixxed. maybe try that?
there is no air in my clutch line my mechanic changed the tranny fluid and we bleed the clutch to make sure there was no air in there. he said the only thing left that it could be is the clutch/pressure plate or something.
the clutch catches pretty much almost all the way out. whats a good stage 1 clutch to go with? and how much is a master slave cyl?
it doesnt grind going in gear, just so hard to put it in gear i have to force it with lil strength effort lol
