Help a french guy
Help a french guy
Hello everybody
I prepare to modify my S2000.
But I hesitate between Supercharger (with Aftercooler) and a 2.3 Stroker kit.
In France, we go more quickly on the road in general : 100 mph minimum on motorway
So many people disadvised to me installing a Supercharger (i prefer Vortech) because mechanics suffers too much.
What do you advise me? Stroker kit 2.3 or Supercharger.
Thanks for all
Thanks for all
The problem is that if you add a super or torbocharger, then you will need, beefier brakes, LSD...etc. In the end you might be better off bying a whole higher performance car.
My advice: Ne fait rien, et va plutot t'amuser dans les petites routes de campagne (Don't bother, and have fun in all these little backcountry roads)!
If you still want to modify it, then rather go for the stroker kit, or even the gear ratio kit; and also, even if it doesn't make such a difference, a CAI is a nice, easy mod to have.
Another Frenchman .
Another Frenchman .
Another Frenchman .
Another Frenchman .
Originally Posted by FrenchS2000,Sep 21 2006, 05:48 PM
What do you mean LSD in english ?
One thing to consider for high speed purposes is heat soak. If you want to drive for hours and hours with the extra heat produced by a supercharger, you might have to consider extra oil cooling capacity.
Help a french guy
A stroker kit might be an interesting option, although you would then be looking at elevated piston speeds. Honda dropped the redline on the 2.2L engines for this reason. This would have to be a concern if you go this route.
The OP didn't really say what he wants the car to do. Do you want to get up to speed quicker? Do you want to drive much, much faster? Do you want the capability to increase your speed quicker? Do you want to maintain the same kinds of speeds you currently do now, but with more ease? Depending upon what you are trying to do, you might want to consider going numerically LOWER final drive gears AND put on a S/C. Until you state what your purpose is, this last option cannot be ranked with any accuracy.
Originally Posted by hecash,Sep 22 2006, 06:16 AM
I put 60,000 plus miles on my supercharged 00, stock drive train, stock brakes (Hawk pads) and a ton of track days. I did not break the drive train until I added water injection and that was just before the car went to the "great beyond."
http://www.pocketrocketsracing.com/hoacf2f2s22s.html
The price is
Originally Posted by FrenchS2000,Sep 22 2006, 08:36 AM
Turn your F20C s2000 engine into a big block 2.45L monster
BTW, either of the existing stock supercharger kits will give you way more gains and for much less trouble.
Originally Posted by xviper,Sep 22 2006, 12:12 PM
I can't quite get past they think a 2.45L, 4 cylinder engine is a "big block monster".
Are European f20c's the same spec as jdm with an 11.25 compression ratio rather than the 11 to 1 compression ratio we have here?
That and fuel availability may affect an US designed SC kit. I don't the answer to that but it would make me lean toward an AEM system so I could tune it to fit my environment.
fltsfshr
