HELP! coolant leak
HELP! coolant leak
Ok so today I noticed the smell of coolant and I didnt realy think anything of it and I was driving around and then I kept smelling it every time I got in my car so I looked and there was coolant sprayed everywhere in my engine bay. I filled the reservoir up with water any by the time I got home (about 7 miles) almost all of the water was gone. What could be causing this?
Originally Posted by sIIooo,May 19 2007, 10:11 AM
Ok so I had it pressure tested and the radiator is bad so I ordered a new one and it is coming in. How hard is it to install the new radiator? Does anyone have a write up on it?
nothing is really holding it down other than the two upper mounts on each side of the radiator .. i could be wrong.. since i havent messed with any s2k yet
Originally Posted by Project22a,May 21 2007, 04:27 PM
Installing the radiator is cake; now bleeding those damn air pockets out...
Welcome aboard. Radiator replacement is a piece of cake:
Drain radiator using drain plug in center bottom edge of radiator (engine side)
1) Disconnect fan motor connectors going to the fans
2)Disconnect fan switch on lower left (engine side)
2) Remove the radiator upper brackets located on either side of the top of the radiator-remove radiator (when you replace torque two bolts to 8.7 lbf.ft torque).
3) remove fan shroud and other parts and put on new radiator
4) replace radiator making sure the lower radiator cushions are "on the stubs".
5) Replace fluid and check for static leaks.
6) Bleed system-hard to describe here but do a search on the board and I'm sure you'll find the location of the two bleed items (bolt and cap). Cap is on pipe which traverses the firewall behind the engine. The bolt is on the right side of the head just below the joint line of the valve cover and head. Jst behind a hose at the front edge of the block (do a search here).
Additional:
Replace the o-ring on the fan switch. Part is available at www. majestichonda.com or other sponsers here.
Fan bolt torque is 5 lbf.ft
Fan switch torque is 17 lbf.ft.
Utah
Additional:
Utah
lilsharky
09-27-2011 05:28 AM
