Help CEL won't go away
Hi all. I'm a new owner of a rio pearl s2000. My issue is that a CEL light won't go off. Hooked it up to a comp and it said O2 sensor high voltage bank one sensor one, changed the sensor (upstream) and reset/erased the code. Drove for a few hours light came back on now with a code bank one sensor two being the second sensor. While I was changing the sensor1 I noticed the previous owner had already put 2 foulers (spacers) for the second sensor and the sensor looks new. Car has Megan racing headers with what seems like a full cat, maybe a high flow I'm not sure. I will try to remove the one of the foulers and see if that works, also i put 93 octane on the car since i don't know of a gas station with 91 octane. I'm in Bridgeport CT so if anyone near by want to lend a hand let me know. I need to pass emissions and it's beginning to be a headache not to mention the light on the dash is annoying. Any suggestions/ experience Thanks all
Thanks for the imput, i will take pics sometime this week when i get the car on a lift or jacked up. Also passing by a buddy's shop to hook it up to a reader again and erase the code temporarily, i feel like the S burns alot of gas when the CEL light is on.. maybe its a mind thing, I dont have a light foot either.
Given that the previous owner bothered to install the anti-foulers to begin with, you most likely have a high-flow cat. If they removed the high-flow cat prior to selling you the car, you would think they would have removed the anti-foulers at the same time. Try looking up pictures of a stock s2k exhaust system online and compare it to the cat currently on your car.
