Help! Car wont start after it is warm!
I have a MY 2000, i have been having an issue where the car wont start after i drive it for 15 minutes or more, unless i press the gas pedal all the way in and keep my foot on the pedal until it stabilizes..and once turned on it also stutters a bit. I changed the map sensor but it didnt help. Any ideas? This is getting annoying.
The status of sparks plugs and valve adjustment?
Thanks!
Thanks!
I changed the spark plugs not too long ago maybe a month and a half, and i have been having this problem way before that. And as far as valve adjustment i have little knowledge about lol, some one just told me that it can possibly be the tps sesor?
How did the spark plugs look?
Do a compression test.Mine turned to be a leaky head gasket.Litle amount of coolant was running into 3rd and 4th cylinder and that caused the hesitation at start up and the misfiring.
Thanks for the recommendation, I will be doing the compression test on Sunday hopefully. what kind of numbers should indicate good compression?
