HELP! CAR IS PULLING
Old 09-12-2011, 09:55 PM
Ap207's Avatar
I know its a little late but i figured the problem out. The tires were mismatched but one of the tires was almost 2 inches bigger than the other . yes both were 245/45/r17. the people at tire kingdom were shocked because they had never seen that before. o, it was two inches bigger even after it was completely bald. lesson learned.
Ap207 is offline
Old 09-12-2011, 09:56 PM
Ap207's Avatar
Originally Posted by haywoodjablome
Originally Posted by s2cho' timestamp='1305833059' post='20593430
get a FULL alignment,
not just taling about making sure the wheel is straight.
im talking about the cambers, on at lest on one wheel i think the camber is off
Please stop giving advice. Your history proves you're REALLY bad at it.
LMFAO
Ap207 is offline
Old 09-12-2011, 09:59 PM
Ap207's Avatar
Originally Posted by Ap207' timestamp='1306311092' post='20612888
yes, the two rear tires are diffrent brands but i doubt it can be that. (im not a mechanic but ive gone thru a fair amount of tires in a yr to have mismatched a couple pairs )
Some people are simply beyond help.
Your wrong, it wasnt the mismatch of the tires, it was an actual physical defect of the tire done by the manufacturer . thank you.
Ap207 is offline
Old 09-12-2011, 10:20 PM
haywoodjablome's Avatar
Originally Posted by haywoodjablome' timestamp='1306342190' post='20614114
[quote name='Ap207' timestamp='1306311092' post='20612888']
[/quote]
1. You have 2 tires of different manufacturers on the rear and you think nothing of it.
2. You think that just because those tires are the same size that they are actually the same size.
3. You actually think that 2 tires of different makes pumped up to the same pressures will be the same.
4. You and the tire shop are surprised that they aren't the same diameters.
Both you and that tire shop are way beyond any help.
haywoodjablome is offline
Old 09-13-2011, 06:04 AM
Billman250's Avatar
Received 1,381 Likes on 828 Posts
It's not a defect. Tire sizes differ with manufacturer.
Take the stock rear SO2 tire on the AP1. It is 225 50 16. Put it next to another tire, different brand, same size. They are nowhere near the same size. The SO2 225 50 16 actually MEASURES 245 45 16. This is why it is recommended you use a 245 45 16 if you run any other tire than stock.
Brand, pressure, size, and wear must match.
But hey what do I know
Billman250 is offline
Old 09-13-2011, 06:07 AM
Billman250's Avatar
Originally Posted by JohnsS2000
i had a 2006, bought off the showroom with 4 miles and under accell it pulled to the laft too. I was intrigued since the 2001 does not do this. All tires where obviously new and the alighnment was perfect. This may be no issue
This is 100% an issue. NO s2k should pull under acceleration. It should go perfectly straight.
Old 09-13-2011, 07:23 AM
WarrenW's Avatar
I had a couple of mismatched tires on the rear that I posted about in a thread last month. The car pulled to one side under acceleration and pulled to the other side under deceleration. Those tires were the same brand but different models and similar but still different tread patterns. After 14 miles on those tires I realized that wasn't going to work so I got 2 tires that were the same brand and model and that cured it. Lesson learned.
WarrenW is offline
Old 09-14-2011, 02:27 PM
S2_4SHOOR's Avatar
glad it's fixed!
S2_4SHOOR is offline
Old 11-21-2011, 08:40 PM
Ap207's Avatar
haywood, i could be dying in the desert and i wouldnt want your help. First and foremost, when i say the tire actually had a physical defect. I mean it had a physical defect. Tire kingdom brought out the exact same tire (model/size) and my tire was still f@#king bigger. ps. go home, take a journal and right this down. the only thing here that is beyond help is you man....
Ap207 is offline
Old 11-22-2011, 05:02 AM
There are carcasses in the desert from fools and idiots. Die away. You can't help idiots.
Quick Reply: HELP! CAR IS PULLING
