Help! C/F Hood installation.....cant lock
Originally posted by Russ
...and yet another imitation hood that doesn't quite "fit" the bill.
Some other tips,
If you look at w1ngman's pic you can see 4 black rubber stoppers. Guess what folks those are adjustable as well. You can turn those to make one side higher/lower.
Now about the latch, the latch can be adjusted with the bolts that it is attached with. You can get a lot of play out of those bolts. I think you are experiencing the same problems I have though. The latch is not hitting the opening correctly. As you close the hood push the latch inward toward the windshield. Mine kept hitting the metal bracket and not the opening.
Wells......I've played with the bolts that attach the hood to the brackets, but not the bolts on the hood brackets that connect to the car. Ill try those also....Ive played with the latch alot, and it looks like it can ALMOST lock down completely, but is just a little too short. Ill have to try the brackets -> car bolts to see if that can help. I tried totally removing the two rubber stoppers at the front...that didnt help either. Thanks everyone. Ill let you know if i get it on, otherwise i may still be looking for help/advice.
Curious to ask one more question to you...
You're not dropping the CF hood to get it to latch (like we do with the OEM aluminum hood) are you??? You *don't* want to do that...at least as I've been taught. You want to *set* the CF hood gently into the latching mechanism. Then press firmly with your hand...central to the mount-point of the latch/hook until it clicks into a latched position.
Sorry if I'm checking something you are already fully aware of...just good info if you aren't aware of this.
- Dave
- Dave
Oh god I hope he knows that just dropping it won't close the hood and that you need to push down at the latch. If that was his problem, I am driving down to MD and taking his hood away from him.
LOL! And I would gladly give it to you if that was my problem. Actually....at this point I almost wish that was my problem so I could give a quick "DOH!" and get it to lock. Still havent had time to mess with brackets that attach to car, ill try that, otherwise..im lost. it looks like it may be hood pins for me, but i dont wanna so im gonna see if i can get it to work. THanks
Originally posted by north9586
...it looks like it may be hood pins for me...
Oh, Im not knocking hood pins in the least, I just didnt want to pay the extra $$$ and drill the c/f...i mean its so pretty. Good point about the speed and pins though. Looking at yours, they flow well. What kind are they? And if I get hood pins, will it even matter that the hood wont lock? Thanks
