Help Buddy Club N+ coilover adjustment
Lower....
Jack up car remove tire, loosen ride hight nut and run up to the nut set for the spring perch, tighten against spring perch, turn the middle nut in the 3 nut pack now, once ride height is set loosen bottom nut of the nut back and run all they way down and tighten....
To raise, just loosen the ride hight nut and turn the lower nut of the spring perch...
I suggest taking a measurement of how much you need/want to lower it, then measure the height change you want to put in. This will make it easier to get to the ride height you want but also get both sides of the car a lot closer then you would other wise... I do suggest corner balancing after finalizing your ride height.
EvasiveMotorsports
04-30-2018 03:45 PM
decepticondc5
12-25-2016 01:49 AM
