HELP a bro out
HELP a bro out
Hey fellas. I own a 2003 s2k with 90 k miles on it. Car is stock and drove perfectly fine until our of nowhere I started getting a 2-3 grind. HAPPENS ON ALL RPMS above 2k. Only the 2-3 shift. Not 4-3.
I'm assuming synchro is f@#ked.
I located a trans from a 05 ap2. Instead of swapping synchros out.
Questions:
Will a ap2 trans directly fit on my ap1 with no additional parts?
Will I need a yellow box speedo healer to accommodate for the shorter ap2 ratios?
Questions:
Change tranny fluid and bleed clutch first.
It would be very odd for syncros to fail out of the blue and all of a sudden, if they go bad they start to warn you well ahead of time. What fluid are you running ?. Have you checked the clutch rod freeplay , you may have too much freeplay in the clutch rod.
