Help with bolt identification after clutch swap
Hi everyone,
I just got done doing a clutch swap on my MY00 S2000. I had my friend follow me around on the first drive and after about 20 minutes he noticed a bolt get flung up under my car. We turned around and picked it up, and I've spent the past day trying to identify it's location (to no avail). It's a 12 x 1.5 mm thread (17 mm bolt head), which is strange because almost every 12 mm bolt on the car has a 1.25 mm pitch. It also has a "9" stamped on the bolt head, which is also strange because nearly every bolt I can find has a "10" printed on it.
I've narrowed down that it cannot be a transmission bolt. I've checked everyone I can see, and they all have a 1.25 mm pitch. The only 12 x 1.5 mm threads I can find in the service manual are for the subframe bolts (much longer than mine) and for the wheel studs. Does anyone recognize this bolt?
Thanks,
John
Thanks,
John
Thanks for the reply. The rear trans crossmember has 15 mm bolt heads (10 mm thread?), so this is too large. The upper trans bolts (to the crankcase) are 12 x 1.25 mm, which is finer thread than this. They are also quite a bit longer.
Such a mystery. I'm trying to do the 45 minute commute to work in the morning and would like to figure this out. Any more help is appreciated.
That's the hope. However after a clutch install with the car just about half apart, I'm paranoid that it came off of mine. If no one recognizes this bolt then I'll dismiss it as a coincidence, but for now I'll have to drive the car hoping it doesn't fall apart haha.
The bracket that also clips to the wire harness and a hose? Checked that, top (manifold) and bottom (tranny) bolts are there and tightened. The car is driving great, no strange noises or rattles. Starting to believe it could be a total coincidence... thanks a lot for the help. If anyone does recognize the bolt I would like to know.
