Help Biggg Problem Here!!!!!!!!!
take a few pics of your engine bay, it will greatly help us get an idea of what's wrong. Also, did you doulble check your vaccuum hose connections, are you sure they are right?
Can you remove a coil and one of the plugs and confirm this, chan? I think you should be able to have someone press the start button and you can watch the plug gap for a spark. You want to be sure it's the ignition and not the fuel delivery that's your problem.
If it's the spark, then I think your problem is something that the ECU doesn't like. You'll need your diagnostic codes to nail this down, friend.
