HELP! Alternator only reading 6v
Hi, i changed my clutch yesterday and to my knowledge, i connected every cable back. I only disconnected the plugs near the tranny, and the crank shaft sensor when it comes to the electrical part. the clutch turned out great! PITA NEVER AGAIN WILL I DO IT BUT ITS GREAT. the problem is that the alternator is not charging. the dash lights are out, so is the radio. I was able to get a voltage meter and only read 6v out of the output cable on the alternator. The only thing i left disconnected was the bracket that holds on the line of plugs that goes to the tranny which is suppose to hold on to a tranny bolt. to my knowledge, all the grounds look good. I need to car running monday. PLEASE HELP, ANY IMPUT IS ASKED ! THANKS AND GODBLESS.
Check your fuses. There's two fuse, one under the dashboard and one under the hood. It's a 15A, labled ALT I believe. I had the same problems. There should even be some spare fuses so there's no need to buy new ones.
Thank you , turned out to be the primary and secondary 02 sensor being connected to each other instead of the cars wiring and the cars wiring connected to each other -_-. NOTE TO SELF. DONT LET IDIOTS HELP YOU FINISH your CAR
How is that even possible?!
i was thinking the samething lol
