HELP!
HELP!
Ok so I installed my neo with boomslang harness. I did the initialize and set the cylinders to 4 and throttle to arrow up. Vtec control on and 6in 6out on throttle inputs. I set air map to no correction and vtec to no correction. The CEL came on.. Did a lil reading and saw this has happened before.. I let it idle and it was fine. Drove it around and couldnt get it to engage vtec. I set the vtec control to 6000 lo<hi and 5900 hi<lo. This fixed the vtec problem but still have the cel light. I have not reset the ecu yet though. Am I missing something to cause a light?
Nevermind, I reset the ecu a couple times and after redoing the initialization it is fine now. I must have made a small mistake on the first initialization.
