HELP... 02 Sensor
HELP... 02 Sensor
Ok, so I'm installing a test pipe and after some struggling (due to rust) I can get all the bolts except for the 02 sensor bolt out. I tired to disconnect the wire from the cat, but could not. Is there a trick to this??? This is driving me nuts.
So, the actual sensor is stuck in there? I used a large Crescent type wrench and "snapped" it loose to get it started. A little Liquid Wrench at the sensor base will help if sprayed on 1/2 hour before you try to unscrew it. Oh, make sure it's "lefty loosey".
Since I can't seem to get the bolt loosened/ sensor out. Can the wire be disconnected from the actual cat? This way I can remove it from the car and work on it in a vice or something.
Yes follow the wire up to where it plugs in and un hook it! then pull the whole cat. out! Theres also a few clips that hold the sensor wire too. just unhook the wire u shouldnt have a problem with this.
