Heater won't heat
Heater won't heat
Hi. Today was feeling quite cold, so I went to turn the heater on, but it only blew cold air out. The temp sensor was on the middle bar so I know the engines warm. But even after blowing for 10 minutes it's still cold. Is this a quick fix or do I need to take it to Honda.
Phil
Phil
take a look under the hood, above the header on the looped coolant hose is the blend valve that lets coolant into the heater core. There's a little cable that runs off into the firewall (looks like a throttle cable). Have someone rotate the temp knob in the car and see if the lever on the valve moves.
My roommate's S2000 had this problem a few weeks ago, found out that the valve wasn't opening (much). I pulled out the pass. airbag and saw the cable stripped out of the mount right by the motor that controls the valve.
Andrew
Andrew
iv checked the coolant, was slightly below min but the hose still managed to reach the fluid. iv topped it up to make sure. is there any thing else i need to do to clear the bubbles (if thats the problem) from the sytem.
iv added coolant. the knob turns. tried "burping" the car but would get a slightly warm air when driving fast (70mph, lol). but would go bact to cold air when stopped and restarted. anyone have any ideas. its getting chilly now.
thanks
phil
thanks
phil
thanks
phil
thanks
phil
rebleed the car to be sure you get all the air out possible. while bleeding make sure the heat dial is turned to all the way hot. if this fails then it might be time to check the thermostat.
Here is a thread Marcucci posted a few months ago when he had similar issues.
https://www.s2ki.com/forums/index.php?showtopic=754685
