heated the brakes up a bit too much haha
Old 08-28-2011, 01:51 PM
davidc1's Avatar
Another good place to get fluid in stock is a motorcycle race shop. I just got some Motul RBF 600 at Malcom Smith in Riverside.
While I'm sure there are some who will disagree, The stock pads are up to track days without any problems. For the typical 20-30 session, they'll be fine, unless you are a very experienced racer.
Canyon runs downhill in very hot weather are a different thing. Much harder on brakes that track days simply because you never are off the brakes long enough for them too cool.
If you didn't smell anything funny, then your pads were fine. But you need better fluid to keep from boiling.
Old 08-29-2011, 03:17 AM
starchland's Avatar
turning rotors=taking away mass...if you think about the rotor as a heat sink, well...
Also,experienced racer should mean that your using the brakes wisely perhaps?
Old 08-30-2011, 01:21 PM
unison21's Avatar
definitely upgrade your brake fluid to DOT4. As others have said, Motul RBF600 or ATE SuperBlue/SuperGold are both great.
Old 09-03-2011, 03:51 PM
Jstone_ap2's Avatar
if im flushing my system and filling with ate super blue how many bottles will i need to buy?
Old 09-03-2011, 03:53 PM
Jstone_ap2's Avatar
and in no way am i saying im an "experienced racer" im just saying im not new to driving in race conditions, this has just never happened to me before
Old 09-03-2011, 04:04 PM
psychoazn's Avatar
The stock pads will fade if you brake from 100 to 40 once at ABS.
As others have recommended, brake fluid first, and then pads if you start smelling stuff.
Old 09-03-2011, 04:14 PM
Jstone_ap2's Avatar
yeah under hard braking i so smell the pads
Old 09-03-2011, 04:15 PM
Jstone_ap2's Avatar
amount of ate super blue to buy? bump
Old 09-03-2011, 04:25 PM
psychoazn's Avatar
A one liter bottle will be more than enough to flush your whole system twice.
Old 09-03-2011, 04:28 PM
JohnsS2000's Avatar
fluid should be bled out, thoroughly every 3 years at least to avoid moisture . I have done mine 2 times in the last 6 years and will be again soon. doing this will also help prevent caliper failures due to moisture causing rust in the brake system,MY01 has original calipers where as I have seen alot of newer cars with calipers stick/ceize
Quick Reply: heated the brakes up a bit too much haha
