headlight out
headlight out
light went out today so removed the bulb and called autozone and told $149.00.almost sh#t.found one on amazon.com for $53.00 and with overnight shipping it was $69.00.there must be a lot of mark up on these bulbs
Originally Posted by Slows2k,Nov 19 2009, 04:54 PM
You should swap the bulbs side to side to see if you really have a bad bulb.
AND.........if you go buying bulbs off Ebay or Amazon you might not get the same heat/color range. Definitely go swap them first, then you need to go find the best price on an OEM or equivalent.
i received the other bulb today and decided to try and change it through the fender hole drivers side.just remove the coolant bottle and it was less of a pain then removing the tire and liner.if you never changed one before i would go through the liner on one side so you know how it comes apart.
