Have You Replaced Your Rings?
I've been seeing my oil consumption and smoking engine issue get worse and worse.
Just replaced all my plugs and coils and my cat is shot. Its time to replace the rings and I need some advice from someone who has done it.
I'd like to know:
1.) Did you do it with regular rings or the oversized
2.) Did you machine the cylinders or do work on the head
3.) Did you pull the motor or drop them from below
4.) Did it work
I'd like to know:
4.) Did it work
Have you done a compressiona and leakdown test ?. You might have bad valve seals and just doing the rings might not solve all of your issues.
When my factory motor blew we bought a used f20c and we had new rings, bearings, and seals installed. No honing done to the block as the cylinders were in good shape, and we did not use over-sized parts. The engine was out of the vehicle so all work was done on an engine stand. While the engine was apart we had the valves lapped and new new valve seals installed. So far so good.
May I ask you how much (without the engine price) it cost to do that job?
What did it cost you to do the buildout on the used engine?
Depending on your miles more then likely it is bad valve seals. Get a compression test and leak down test to determine exactly what it is but if it's just valve seals it should be a lot simpler depending how far you wanna go. Mine were bad and I decided to just rebuild the entire head and ended up finding my exhaust guides to be bad. For reference I have 110,000 miles on the car and my compression numbers were 220psi across the board before the rebuild.
Got leak down and compression yesterday and they were both fine. Alex at Ballade Sports in Garden Grove, CA then did a valve adjustment and it solved the problem. Car is much quicker now too, amazing how my last shitty adjustment job screwed up my car so bad. Alex saved my S2ki and made it feel brand new
ScienceofSpeed
Member S2000 Classifieds and For Sale
09-18-2009 03:14 PM
RossoS2K
06-30-2004 12:05 PM
