Has anyone used the Emanage with injectors 150% bigger than the stock one?
The Emanage's instruction recommends to use injectors of up to 150% bigger than the stock one. I think the stock injectors are only 389cc/min. This means that the emanage can only safely manage injectors of 550cc/min or less (or 583cc/min if you can get them )
I am planning on running 14 psi (1 bar) with my vortech sc setup when my engine is rebuilt. I am still researching EMS and injectors at this stage. So if anyone has any good advices are more than welcome
Has anyone tried bigger injectors with the emanage?
Is there any problem or difficulty?
Many thanks in advance
The '150%' recommendation in the manual is not really an E-manage limitation but a stock ECU issue. Basically Greddy don't recommend going too much bigger because then you have the injector ratio set to 60% or less and are feeding very low MAP signals to the ECU (injector compensation and reduction only alter the MAP signal). The ECU uses the MAP signal for more than just injector phase. It also effects timing.
